Contact Using Optistruct
I am using HM 17.2 (Optistruct) and have no Radioss.
My problem is using Contact in Optistruct. Somehow I can't get the result I am expecting because of the problems I have in my model.
The contact doesn't seem to function the way I want it to be.
There are errors that I don't get. Some errors are:
*** INFORMATION # 4739
The structure of surface-to-surface contact element is quite different than
that of node-to-surface contact element. No internal CGAP/CGAPG elements are
created for surface-to-surface contact.
*** INFORMATION # 3433
MUMPS solver is used by default for nonlinear analysis at subcase 1.
I have only 1 version of HM and have only Optistruct too.
Educate me please /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Could you also share the .out file of the run?
