🎉Community Raffle - Win $25
Join and Win
Regarding Mid surface
How can we get a better mid surface for plastic parts?
1 - 1 of 11
    Hi,
    There is no automatic method available to extract mid-surface of complex plastic parts. As mentioned in the documentation.
    Always start with auto mid-surface option.
    1. Divide entire single component in to multiple components. Then again try with auto mid-surface or other subpanel of mid-surface.
    2. You can generate mid-surface using manual method like ruled, skin ,drag, spline, line drag(mesh & surface generation command)
    3. Surface ,Surface edit, Quick edit, lines & lines edit would help you to generate mid-surface.
    Regards
    Rahul R
