🎉Community Raffle - Win $25
Join and Win
Single lap Bonded joint analysis of Composite laminates and Cohesive zone modelling
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello, I'm Kaustubh Garud ME design Student, Doing my ME project in Analysis of Adhesively bonded joint between composite laminates(static and Fatigue). Can we do that using hypermesh preprocessor and solver? Also, can we create cohesive elements or cohesive zone model using hypermesh ? Please help.
Thank You
1 - 2 of 21
    Altair Employee
    OP
    HI,
    Can you please provide details about adhesively bonded joint?
    You can model cohesive/glue in RADIOSS using PROP/CONNECT and MAT/CONNECT
    Altair Employee
    OP
    Laminate configuration : [90/45/-45/0]s
    total No. of plys : 8
    Ply thickness : 0.3125 mm
    Laminate thickness : 2.5 mm
    Geometry of laminate is given in figure.
    Adhesive length (l) : 25mm
    Adhesive region : 25*25 mm2
    Adhesive thickness : 0.1 mm2
    Tension test results are given in figure. I want  to model this in Hypermesh using cohesive zone and get load displacement matching the experimental results.
    For that cohesive zone parameters are required which can be extracted from 'Inverse method' ie. Trial and error in FEA
    Thank You
