problem with selecting in hypermesh window
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
When I want to select something inside the hypermesh window, for instance a component or even a single element, hypermesh starts to select the geometry line after line or the mesh element after element, adding them all to gether.
Everything else is going fast like rotating, zooming, cycle trough views and menu's. Only this selecting procedure by clicking inside the hypermesh (blue) window is going slow. If I select the parts/elements by 'displayed', 'all', 'attached' etc it also goes as fast as normal.
What is the reason of this slow selecting and how can I fix it?
Thank you in advance!
1 - 3 of 31
    Altair Employee
    OP
    Hello,
    Could you please try these:
    1-) Use the latest HyperWorks updates, especially HWDesktop updates
    2-) Clean up the user files (e.g. c:\users\your.username\hmfiles
    3-) Increase your virtual RAM from the computer preferences
    Hope it works.
    Altair Employee
    OP
    Thanks for the possible solutions, but unfortunately they don't help... Do you know something else?
    Maybe for your info, I have windows 7 installed. Previously with windows XP, Hyperworks 11.0 worked fine on same pc.
    Altair Employee
    OP
    It is solved. My videocard driver needed an update...
