🎉Community Raffle - Win $25
Join and Win
Mesh can't be created
User: "uri"
Altair Community Member
Updated by unknown
The recommended element size is to have 3 elements by the width of the part.
The wall thickness  of the part is 4.5mm so I need an element size of 1.5 mm
When trying to do so I get a message of too many elements, 23.16 million elements.
(23.16 )*4.5(GB)= 104.22GB (Ram memory needed)
I have 128 GB Ram memory.
Should I enlarge my Ram memory to 256 GB?
Please advise.
1 - 5 of 51
    User: "SouravDas0306"
    Altair Employee
    Updated by SouravDas0306
    Hey Uri,
    Actually in installer we config .xml file, and there we need to increase the thrush hold value ,
    C:\Program Files\Altair\2019.4.2456\InspireCast2019.4.2456Dev\hwx\plugins\freedom\profiles\c2c\config\solverConfig.xml, (you can  change the setting in this file)
    <param txt='Max num of elements allowed for run' dv='20' id='max_allowed_num_elem_run'/>
    change the 20 value to your requirements.
    I have a question for you Uri: How did you calculate the RAM
    Thanks
    User: "uri"
    OP
    Updated by unknown
    The 4.5 GB RAM per 1million elements is a #, I got from Altair person...
    Altair Employee
    Hi Uri,
    Thank for the answer, getting back to our previous conversation I would recommend you to increase the RAM , although running with 20 million elements is not that worth. Anyways is it possible for you to share the file? I can have a look at it.
    Thanks
    User: "uri"
    OP
    Updated by unknown
    Hello
     After changing Max num of elements allowed for run' dv='20' id='max_allowed_num_elem_run'/>  to 30
    it worked O.K.
    Altair Employee
    Hi Uri,
    perfect :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'> , let me know if you need any further help. We will be happy to help you.
