How do I change the number of cores a solver uses as my licensing has changed and it is trying to use too many cores and crashing the solver
Maybe you reinstall the FEKO.
Hi, yes that's what I did in the end and it worked, thanks
Hi Paul,
You can set the number of cores here:
Best regards,Torben
