- Does LeadName use a specified SAS format and variable length, or is it defaulting to something unspecified?
- What is the length of the LeadName column in the database?
- How long is the data in LeadName (as opposed to the length of the variable) in the first record being read?
- Is the database made up of SAS data sets, WPS data sets, or is it a relational database?
- If the answer to Q1 is not a specified format and length, is it possible to test an updated SQL Select clause with FORMAT= and LENGTH= specified after LeadName in both 4.4 and 5.23?
Hi Mary,
Please can you post the SAS program you are trying to run? It may not necessarily be an Altair-related issue.
............Phil
It took us a while to figure this out. First it was running at my machine which had 5.23 version installed. The table only has first letter populated. Then we ran at a different machine which has 4.4 version installed. It populated a full name. Therefore, IT uninstalled 5.23 and reinstalled 4.4. Now, I see the full name is populated.
I just wonder there is a patch or something we can install to fix this issue instead of rolling back to 4.4 version.
Hope this helps.
Hi Mary,
............Phil
Thank you both.
I can't show any sas code here because that will against our agency policy.
However, I can show you two versions of Altair:
same sas codes. two different versions of Altair and we get two different results.
Thank you both.
Hi Mary,
I understand why you can't post your failing production(?) SAS program, as I work in a regulated environment myself.
However, Nico and the Altair SLC developers will not be able to resolve your issue without a lot more detail on what your SAS program was actually doing. They can perform miracles, but can't with zero information and their hands tied behind their backs!
Can you create a simple non-business-critical SAS program that exhibits the same issue, but which can be posted here, or, at least, posted directly to Nico and the developers?
..........Phil
PS. I know Nico would like to tell you this too, but he's way too polite! J
The code is just selecting data from database.
select distinct caseid,provname,...,LeadRole,LeadName,
It is the LeadName not fully populated.
Hi Mary,
I have a few questions that may help us help you:
I have been working with SAS programs and data sets since 1981, but sometimes the results can be counter-intuitive.
.................Phil
Hi Mary,
............Phil
