dear all,
i have defined S2S contact with static coefficient of friction 0.1.
roller edge is penetrating inner ring edge.
how can i resolve this issue.
Hi
Can you try with STIFF on PCONT?
This may help remove penetration but it may structure stiffer if you provide very high value.
Start with a value of say -100 and check the results.
Dear Prakash,
please suggest any corrections.
Can you try with PCONT and use STIFF and Mu1 to provide static friction and check if that helps?
Hi
