Tria mesh and free edges
Zaily
Zaily Altair Community Member
edited October 2020 in Community Q&A
Hi guys,
I have  a model composed by about 27 parts. This model is a STEP file. After importing the geometry into Hypermesh, I linked the parts in contact between boolean operations. Now the topology of the model is correct and I have created a 2D mesh of all parts. When I want to create a 3D mesh of all parts by tetramesh command, the status bar shows ' Tria mesh and free edges'. After  I used Tools > Edges panel for check, there is ' no edges were found.Selected elements may enclose  volume'. However, when I executed the Boolean operation and used the  tetramesh command directly, I successfully created a  3D mesh of all parts.  Who can tell me the reason? Thanks!
Welcome!
Answers
  • Pranav Hari
    Pranav Hari Altair Community Member
    edited April 2019
    Hi Shi Feng
    Can you please share the model file
  • Zaily
    edited May 2019
    Thanks!!!
    I have solved the problem. But there is a new problem. Could you help me?
     'RBE2      174990   26374       0    3827    3828    3829    3830    3831'
      *** See next message about line 26437 from file:
          C:/Users/Zaily/Desktop/Altair_practise/HM/5_1_1.fem
      *** ERROR # 1000 *** in the input data:
      Incorrect data in field # 4.
     As a newbie, I don't know how to solve the error according to the error message. Could you give some suggession?
  • Pranav Hari
    edited May 2019
    Hi Shi Feng
    Can you please share the .OUT file
Welcome!
Welcome!
