1 - 8 of
81
I have imported a geometry with several parts (no mesh). I want to import and replace an existing part with a similar new part . How can we do that?
For Geometry above method is good & if you you want mesh based update then Part replacement is good based on user profile.See attached sceenshot.
What I meant was that how to put the new part (no mesh) to the location of the old part so that they coincide with each other. When you import a new geometry it will have deferent orientation and position.
using translate option organize them as required.
Instead think about positioning the CAD part using POSITION option.
There is only one global coordinate system after importing new part in my model. So what should I do in this case? How do you identify positions?
Each part is imported in different component. If you import new part, you will found new imported part under new component having the name like <Component_Name>.1. So just delete old part.
