free body diagram in HV
Yuyang Song
Yuyang Song Altair Community Member
edited June 2021 in Community Q&A
i am trying to use Hyper view 2019.1
after i load inp file, and odb file.
it says no GFORCE results available
how could i include them in...
Welcome!
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021
    Please, make sure you have requested the nodal forces results
  • Yuyang Song
    edited June 2021
    how could i include NFORC Force/moments in Abaqus again?
    btw, does it work with Dyna output? i used to work with dyna more than Abaqus
  • Yuyang Song
    edited June 2021
    how to get NFORC force/moments in Abaqus?
    BTW, does this HV support Dyna results?
    i am working with Dyna more than Abaqus...
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021
    the help says it works only with Ansys, Nastran, OptiStruct and Abaqus.
    I'm not familiar to Abaqus solver, but i would say it is inside the output block options in the loadstep.
  • Yuyang Song
    edited June 2021
    i did try add the NFORC force/moments in abaqus, but it still has same error as no GFORCE results available...
    btw, a side topic,  how can I show the boundary condition, such as force, fixed node in Hypermesh so that when i present out, it shows clearly..
    not the manual approach...
  • Yuyang Song
    edited June 2021
    here is the model i want to give a trial
    if you can show me based on this model, that will be great.
  • Michele Macchioni
    Michele Macchioni
    Altair Employee
    edited June 2021
    Yuyang,
    chiming in here and trying to give you some extra info:
    Issue with ABAQUS results:
    is your model by chance a pure solid one? There was an issue with HV FBD where the tool assume you always have Forces AND Moments. Latter ones are not available in NFORC output for ABAQUS (in solid models).
    Showing Loads & BC:
    HV does not have this option (yet). For OptiStruct/Nastran/ABAQUS/Ansys you can use FBD tools in HM directly (suggest actually to use the aerospace FBD) to have the combination of displayed fbd + bcs
    DYNA FBD:
    We do not support LS-DYNA fbd workflow yet. That being said, and please, bear with my limited knowledge w.r.t. this specific solver profile, if I am correct, you may need defining *DATABASE_CROSS_SECTION and/o *DATABASE_SECFORC to get forces and moments at a cross-section (which I see missing in your master file)
    BTW: I hope you can share with us as well the results file from the model you sent.
    Hope this gives you more insights.
    Thanks
    Michele
Welcome!
Welcome!
