🎉Community Raffle - Win $25
Join and Win
Modeling Cable with Stranded Cores
User: "dip00"
Altair Community Member
Updated by dip00
Hi,
I am trying to model cables with stranded cores. Any suggestions on how should I approach.
Thanks in advance
1 - 3 of 31
    User: "oussama1"
    Updated by oussama1
    Hello,
    it depends on how the stranded cores are twisted. let's suppose stranded cable with 4 wires twisted together. you can use analytical curve button in FEKO. please the attached images. in my examples all the cables are not touching each others. you can change the radius of the twisting to make them touching.
    if you need any thing else i m here to help. (send your cable format in order to help you building its model) :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    User: "oussama1"
    Updated by oussama1
    look to the attached image, i have changed the twist pitch and the radius of twisting.
    User: "dip00"
    OP
    Updated by dip00
    Hi. Thanks a lot for the insight.
    How are you defining the harness and cable specs though?
    Also, do you have any idea regarding how to measure input impedance for cooling fan motor and PCB traces?
