What is updated command for *materialupdate in latest HyperMesh 2021 version?
Akshay Manthekar
Akshay Manthekar Altair Community Member
edited June 2022 in Community Q&A
Hi Guys,
I want to know how to update material for property using tcl command.
In hm 2017 I used this: *materialupdate properties 1 "$mat_name"
I know that *materialupdate is deprecated and now we use *setvalue.
Does anyone has idea how should I write it in updated version?
Your help is much appreciated.
Thank You!
Welcome!
Answers
  • Ben Buchanan
    Ben Buchanan
    Altair Employee
    edited June 2022
    The following should work for you:
    *setvalue prop mark=1 materialid=[hm_getvalue mat name="$mat_name" dataname=id]
  • Akshay Manthekar
    edited June 2022
    Hi Ben,
    Thanks for your response.
    When I used the above command, it is giving error like:
    hm_getvalue : Requires 3 parameters
    In documentation of hm_getvalue, only 2 parameters are needed and others are optional.
    Can you help?
    My code look like this:
  • Ben Buchanan
    Ben Buchanan
    Altair Employee
    edited June 2022
    Hi Ben,
    Can you help?
    There is a space between mat and name (not an underscore) so like below the three parameters are material(entity type), name=$mat_name(how you are identifying the desired entity) and dataname=id(what you want).
    hm_getvalue material name=$mat_name dataname=id
    https://2022.help.altair.com/2022/hwdesktop/hwd/topics/reference/hm/hm_getvalue.htm?zoom_highlight=hm_getvalue
  • Akshay Manthekar
    edited June 2022
    Thanks a lot, Ben!!
    This is exactly I was looking for :)
Welcome!
Welcome!
