🎉Community Raffle - Win $25
Join and Win
Capture image with user orientation requirement ( node information based )
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello All,
     i'm trying to capture image (node id>attached attached elements > for loop to take care of adjacent elements).
Issue : capture image should be in isometric view with center reference as node (current script orientation issue).
Please help me thanks in advance.
script:
 set node(id) '
169122
275259
    foreach nodeID $node(id) {
      *displaycollectorwithfilter components 'none' '' 1 0
      *createmark nodes 1 $nodeID
      *nodemarkaddtempmark 1
      *findmark nodes 1 257 1 elements 0 2
      for { set a 1}  {$a < 60} {incr a} {
      *retainmarkselections 1
      *createmark elements 1 'displayed'
      *findmark elements 1 1 0 elements 0 2
   *window 0 0 0 0 0
  *jpegfile
  *nodecleartempmark
1 - 4 of 41
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Using command *view iso1
    Before *window 0 0 0 0 0
    Altair Employee
    OP
    Hi,
        It gives me iso view is there any way to capture by keeping input node as centric?
    (node corresponding region is focus of images, accordingly view)
    Thanks.
    User: "tinh"
    Updated by tinh
    Display only elems attached to the node,
    use *window 0 0 0 0 0
    Then capture it!
    Altair Employee
    OP
    Hi,
          Rotation may help (each rotation {till 180 deg} measure node position,  distance with respect to global X,Y,Z  and  nearest distance to global) working on it.
    Regards,
    Anil.
