There are different options to model power electronics. You can use elements from Spice library or Modelica/Electrical inside Activate, or you can use Altair PSIM which is a simulation software specifically designed for power electronics and motor drives. With the PSIM co-simulation block, PSIM models can be used in Activate.
Hi Sangeet,
