frequency response analysis
1 - 12 of
121
Strain gauge measures engineering strain. so you want to get the engineering strain, is it?
True strain= In(1+Engineering strain) where true strain is what you get from FEA analysis. You can use expression builder in HyperView to get the results.
In HyperView click Derived results to write mathematical expression and this expression will be reflected in the result type.
Hi,
output the strain in HyperMesh and follow the steps below:
in HyperView,
1)plot the strain results and change the averaging method to simple
2)on the graphic window right click and select query-->nodes.
3) click the nodes and you should the see the contour value for that node.
this will average the contour results of the elements to the nearest node.
Hope this helps.
you can also get the results from query panel in HyperView.
