Hypermesh core has detected a non recoverable error
Hi,
I am getting this error: 'The Hypermesh core has detected a non recoverable error' while deleting some surfaces from my model.
I have also tried to delete the hypermesh settings from my documents and temp folders. Unfortunately it does not work.
I would be glad for your help.
Thanks in advance
Hi Premanand,
thanks a lot for your answer.
But i can not understand, what can be changed if i reinstall the hypermesh or update it.
Until last week everything was ok with my preprocessing. We have also tried it on the computer of my workmate, the same issue occurs.
Thanks in advance.
Hi raskolnikov,
I understand your problem. Sometimes, after running number of analysis, certain changes would have happened in the background. So, re-installing would fix it.
Thank you
Hi Premanand,
before i reinstall all the program files, I thought i could turn back to my old hypermesh model.
Now it is ok, but i am not sure that it works until the end of my preprocessing. I hope no problem occurs again:)
Thanks for your interest.
Hi,
Reinstall hypermesh, or update to new version pack,.
Thank you
