🎉Community Raffle - Win $25
Join and Win
Beam
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
Is there any possibility  to create beam2n in Radios?
Because there is beam3n at everywhere and when i use beam3n in my model, beam element aligned error occurs. What should i do to solve this poblem ?
Thanks in advance.
1 - 2 of 21
    Altair Employee
    OP
    Hi,
    For RADIOSS the element type for beam is Beam3n. The 1-2 node define element geometry, the 3 node defines the cross sectional orientation.
    Please ensure the orientation is correctly defined so that you can sort out this error.
    Altair Employee
    OP
    And even if i create solid circle section for my beam , the section type transforms generic section automatically when i import the model again. Why it happens always ?
