Altair RISE
Nominate Yourself Now!
Querying Assemblies and Components in Linux
User: "Anirudh12"
New Altair Community Member
Updated by Anirudh12
Is it possible to query the list of assemblies and components in the terminal ?
I want to produce the output in terminal .
1 - 9 of 91
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Before talking about Linux 'terminal', can you do the same within command area of Hypermesh?
    User: "Anirudh12"
    OP
    Yeah it is .
    *createmark comps 1 'all'
    hm_getmark comps 1
    This will produce the list of components present in the model right .
    Write your TCL script (with above commands) and run it from command line.
    User: "Anirudh12"
    OP
    So how does it identify the model present in the hm  session ?
    Should i specify the model name or session name along with tcl script while running it from command line.
    User: "tinh"
    Updated by tinh
    I think hm cannot return complist to console, hm (and executables) will return an exit code (integer).
    If you want to get complist, use tcl to get and write it to a text file and then read the file in console
    User: "Anirudh12"
    OP
    thanks a lot .Also is there a way to access the hm apis through terminal / use hm apis through any programming language using HM_EXTAPI()
    User: "tinh"
    Updated by tinh
    Yes, you can find it in hm reference help (Ext API)
    There is an example.
    Yeah it is .
    hm_getmark comps 1
    Here's my test to get ID list of all comps:
     > ./cmd2.sh  21 22 23 24 31 32 33 34 35 36 37 38 3 4 1 2 5 39 42 44 46 47
    File cmd2.sh:
     #!/bin/bash HM='/opt/hw/2019.1/altair/scripts/hm' OPTS='-nocommand -nouserprofiledialog -batch -nobg' TCL='-tcl test2.tcl' export ALTAIR_LICENSE_PATH='6200@YOUR-LICENSE-SERVER' $HM $OPTS $TCL 2>/dev/null
    FIle test2.tcl:
     *templatefileset '/opt/hw/2019.1/altair/templates/feoutput/nastran/general' *readfile '/FULL/PATH/samcef_validation_hw2019.hm' *createmark comps 1 'all' set comp_list [hm_getmark comps 1] puts '$comp_list'
    HTH,
    User: "Anirudh12"
    OP
    Thank you @Q.Nguyen-Dai
