To capture element quality check display messages
User: "Roshan Shiveshwar"
Altair Community Member
Updated by Roshan Shiveshwar
Hi,
I want to capture messages those are displayed at the bottom left side of the screen when we perform element quality checks. (Pls refer image).
Actually, I am specifically looking for the value inside the red box.
Is there any way we can capture that value?
Thanks
1 - 11 of 111
    User: "tinh"
    Updated by tinh
    Hi,
    you can get the message text by
    set Message [.mainFrame.bottom.message_label cget -text]
    set WorstValue [string range [lindex $Message end] 0 end-1]
    OP
    Thanks tinh :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />.
    BTW , where do we find these commands in altair help documentation?
    User: "tinh"
    Updated by tinh
    No, they are not documented.
    They are pure tcl commands and listed in tcl manual
    OP
    Oh.. good to know.. Will start exploring them as well. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    User: "Sagar Motwani_20540"
    Updated by Sagar Motwani_20540
    Hi Roshan and Tinh,
    The command 'set Message [.mainFrame.bottom.message_label cget -text]' seems to work fine in Hm 14.0.130. But, is throwing error - bad window or invalid command name '.mainFrame.bottom.message_label', for Hypermesh above HM 14.1 and also HM 2017. Can you please suggest any solution to this.
    Thanks,
    SAGAR
    User: "tinh"
    Updated by tinh
    I don't have hm here so let's check it tomorrow
    There is a command that display the message you can hook, i remember it is in HM_Framework namespace (you try searching it by info procs)
    Don't need to trace message_label widget
    User: "Jeffersondhv"
    Updated by Jeffersondhv
    Is there a command that can be used to run these quality checks and get the output directly from the code?
    Thanks,
    Jefferson
    User: "tinh"
    Updated by tinh
    Thanks,
    Jefferson
    Cannot get %fail directly, you have to calculate it by #fails/total
    Use *elementtest... commands
    User: "tinh"
    Updated by tinh
    Hi Roshan and Tinh,
    Thanks,
    SAGAR
    If you are usinh hypermesh desktop, it is .mainFrame.bottom.leftfrm.label
    In HM, it is referred by variable $::HM_Framework::p_message_label
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    Tinh is right, HyperMesh and HyperMesh Desktop are using different frame.
    @Jeffersondhv
    If you want to correspond both cases, following example can help you.
    if {[file tail [hm_info -appinfo SPECIFIEDPATH hm]] == 'hmopengl.exe'} {
     puts [.mainFrame.bottom.message_icon config -image];
     puts [.mainFrame.bottom.message_label config -text];
    } else {
     puts [.mainFrame.bottom.leftfrm.label config -image];
     puts [.mainFrame.bottom.leftfrm.label config -text];
    Thanks Tinh and Imoto :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> .
    This worked fine [.mainFrame.bottom.leftfrm.label  cget -text]. As you told, HyperMesh and HyperMesh Desktop are using different frame.
