CBUSH SPRING
Hello everbody,
in the following picture you see 3 examples of a spring (CBUSH). The only difference is, that the node in the middle (were the force is) has different coordinates in each example.
I don´t understand why the Results are so different.
In example one (on top of the picture) the result is nearly 0
In example two ( in the middle of the picture) the node is -1 in y-coordinate and the difference is huge!! There the max displcement in Y is -3306
I have absolut no explanation for that.
Thanks for helping /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Here are the three examples, shown in the picture
Hi @marvin1991 Did you provide any CID for CBUSH elements? If not can you keep it zero by card editing the elements and check if this helps.
okay thanks.
But when i increase the force and lower the K1 factor the displacement is still nearly 0 ..but why?
Can you tell me how to define the elemet x-axis? I have never done that before. Maybe you can send me a little example?
Thanks for helping!! /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
This is with a local system and apply stiffness in right direction
We don't, either
/emoticons/default_rolleyes.gif' title=':rolleyes:' />. Please send us your *.fem file
