If I use 3D tetra, there is created error component.
In this case what should I do?
I should modify stp file? Or there is a way to do something after creating error component?
That position has a small edge
Clean it up before generate mesh
Thank you.
you mean change R or something?
Clean up geometry
Means remove small edges, tiny geoms,...
