🎉Community Raffle - Win $25
Join and Win
Intermittent/Stitch Weld Connector Tutorial
User: "Mandy Kramer"
Altair Community Member
Updated by Mandy Kramer
Hello,
Is there a tutorial or how-to video on how to use the connector browser to generate stitch welds along an edge or a collection of edges? Also, I'd like to be able to utilize the "seam-quad LTB" for stitch welding but don't know if that's an option.
Thank you,
Mandy
1 - 3 of 31
    User: "Paulo  Libório"
    New Altair Community Member
    Updated by Paulo Libório
    Hey, Mandy.
    Absolutely. Here's an example:
    Let me go over a few of the connector control configurations:
    • Tolerance: distance between elements to be connected. Hint: tolerances too big might make realization difficult. Try using 110~115% of actual minimal distance.
    • Pitch: should be similar to average element edge length if minimal remesh is desired
      Pitch equal to element edge: image
      Pitch smaller than element edge:
    • Start/end offset: If extremities of edges shouldn't be welded, insert length. Here I used 10 as start and end offsets:
    • Skip Welding: necessary for intermittent welding. You define welded and unwelded (break) lengths:
    For more information on Seam Quad LTB connector, please visit: https://help.altair.com/hwdesktop/hwx/topics/pre_processing/connectors/realizations/seam_quad_ltb_c.htm
    Also, I'm sharing this model with preconfigured control.
    Hope this helps!
    Kind regards,
    Paulo Libório.
    OP
    Terrific, thank you Paulo, this is extremely helpful! One detail question: can you point me to where the "realization details" where you define the skip weld parameters is? I looked in the connector control manager on "Connectors.hm" and this is what I see under the realization details:
    I'm running Hyperworks 2022.2, and when I unrealize then realize the three connector ID's, the skip/intermittent weld disappears and is replaced with a continuous weld. Is this a versioning issue, and if so, which version should I update to for the additional functionality?
    thank you,
    Mandy
    Accepted Answer
    thank you,
    Mandy
    Hey, Mandy.
    I'm sorry about that, I didn't notice which version you were using. The skip welding options was added to all Line Connectors realization in the 2022.3 release.
    You can find the release notes here: https://help.altair.com/hwdesktop/altair_help/topics/release_notes/rn_2022_3_r.htm
    Also, here's a playlist of the 2022.3 Release Highlights:
    Best regards,
    Paulo Libório.
