🎉Community Raffle - Win $25
Join and Win
HM14.0.110.13 save failed in qualityindex panel
User: "tinh"
Altair Community Member
Updated by tinh
Dear everyone,
When I press 'save failed' in qualityindex panel, it save 10 failed elements
I change level to 'worse' and see 1 element violating threshold, but when press 'save failed', it save 10 elements as above.
Is there any hotfix to overcome this problem?
1 - 3 of 31
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    I did not see any thing related to save failed in resolved issue list of 14.120 & 14.130 hyperworks desktop.But it is always good to use latest version with latest patch.Please check same in 14.130
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi Tinh,
    By moving the display thresholds slider HyperMesh will highlight only those elements falling at a certain quality level.
    When user keeps the  display thresholds to worse, the threshold values also get increased (For eg, if display threshods is in good, the warpage threshold value will be 5. If it is kept to worse, the threshold value will be 30). And HyperMesh will only display those elements above the threshold value, that is above 30 and only those elements are saved.
    As Rahul suggested above, please try with the latest patch and update.
    User: "tinh"
    OP
    Updated by tinh
    FYI,
    The issue was fixed in HM version 14.0.130
