Hi every body,
It' me again.
Can some one explain the difference between the "velocity" and the "average velocity" from the result?
I could find any document about the "average velocity" neither from the help session nor the training material.
Thank you!
Hi,
Velocity results shows the Velocity on each nodes. While Average velocity is something that calculates over surface/Region. Now you can co relate this explanation with images above and it will be easy to understand.
Regards
