Surfaces trimming with planes
Tony_21982
Tony_21982 Altair Community Member
edited May 2021 in Community Q&A
Hi, Everyone
       I wonder if there is one way to trim surfaces at one time with several planes that belong to the same normal direction. Right now it seems to only can choose one plane to trim several surface. For example, firstly select the target surfaces which need to be trimmed, then choose the trim direction like x,y,z-axis, but at last only can select one POINT or NODE. So actually I want to realize the function that several surfaces can be trimmed at different position under one directions with one operating, instead of several repetitive operating separately. Certainly it will be definitely the best to trim surfaces with plans under different directions at one time.
         Hopefully someone can help solve this challenge.
         Thanks a lot.
Answers
  • Amith Anoop Kumar
    Amith Anoop Kumar Altair Community Member
    edited May 2021
    I dont think there is an option for several trimming in different planes in hypermesh. But if you want to implement of those kind you can write a tcl code and create a gui for that in hypermesh
  • Tony_21982
    edited May 2021
    Hi, Kumar
         Thanks very much for you quick reply. I know there in no option in Hypermesh panel. And actually I mean to want a TCL code:).  However I  know very little about the TCL or Macro. Therefore I wish you or other companions could help me write one TCL code or Macro to solve it.
          Your help is greatly appreciated.
Welcome!
Welcome!
