calculating port voltages in Feko (receiving antenna)
1 - 3 of
31
Hi mel,
Thanks for your response. I am having problem with meshing. My model produces an error when I do CEM validate.
CEM validation
Error 16232: Isolated (unconnected) segments not allowed. Please mesh the following wire segments finer or ensure correct connectivity:
Line1.Wire5
Could you kindly comment on it?
Just plot the loads/networks results on a new Cartesian graph in POSTFEKO.
The image below for a monopole with a load on the wire port and a plane wave over 3 frequencies solved.
