Steering Grometry
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
In standard baja library the rack is behind the wheel center in steering system by my assemble contains rack & steering arm ahead of wheel center(with respect to driver) so during right turn analysis car turns left side i need to rotate rack in model. How to rectify this problem?
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited December 2015
    Image of output
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Suyash,
    You can change the position of the Rack CG by changing the CG point coordinates under Rackpin Steering assembly folder.
    Check if this helps to modify the model as per your geometry.
Welcome!
Welcome!
