Modelling adhesive joints in a Ply based model
Altair Forum User
Altair Employee
Hi, I am new to composite analysis in Hyperworks. Could someone explain how to define adhesive joints in a ply based model?
The idea is to join two seperate components that are manufactured seperately using adhesive. For example joining the flages of an hat section to another surface.
0
Answers
Hi Mithun,
What type of analysis are you planning?
If it is just a linear static analysis, you can model using Seam weld>> Adhesive
0 -
Hi Prakash,
Yeah, it is a linear static analysis.
Thanks I will try it out and let you know.
0
