🎉Community Raffle - Win $25
Join and Win
Demagnatisation
User: "RAVITEJA_028"
Altair Community Member
Updated by RAVITEJA_028
Hello,
i am doing short circuit analysis for my machine and i want to know the magnetic field Hm.(A/m) . for this should i make a sensor or is there a direct way to see how the magnet values are changing. so that i can decide on my magnet parameters.
thank you
1 - 3 of 31
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    You can also draw your magnetic field once the project is solved by creating « new isoline Â» and you select the region where you want to see the magnetic field. The advantage of creating the sensors befor the solving is to see the evolution of the magnetic field during the solving.
    Best regards.
    OP
    i have seen the results with isoline, but how to create it with sensor. do i need to input the formula.
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Yes if you want use the sensors, you need to use a formula.
