Hello Scott
Thank You
Hi Boris,
Here are three options to consider:
Option 1: Use a Coupler joint. See: How to Crete a Lead Screw in Inspire Motion
Option 2: Use a State Dependent Input (translation of screw is a function of the rotation of the screw rotation). See Inspire Help: State Dependent Inputs
Option 3: If geometry is sufficiently accurate, define a contact between the screw and nut. The interaction is all geometry-based in this case - screw rotates, and as a result of the thread geometry, the nut translates
Hope this was helpful.
Regards,
Scott Z
Hi Boris,
Regards,
Scott Z
Thanks a lot !
Hello Scott
Thank You
Hi Boris,
Regards,
Scott Z
Hello Boris,
Which product are you modeling in, Inspire Motion or MotionView? Methods can be different based on available modeling entity types.
Kind regards,
Scott Z
