🎉Community Raffle - Win $25
Join and Win
How to define thickness for shell elements
Hello
I have meshed a part using shell elements but in my part the thickness varies in different areas of the part (some areas T is 1mm and some areas T is 3 mm).
How should I define T when defining property for this part. I appreciate if you give me your suggestions
<?xml version="1.0" encoding="UTF-8"?>2016-02-17_16-24-29.thumb.png.8b7c3ec9db
<?xml version="1.0" encoding="UTF-8"?>2016-02-17_16-26-50.thumb.png.6a1c8269b6
1 - 3 of 31
