🎉Community Raffle - Win $25
Join and Win
KJOINT2 connectivity
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
To what type of elements KJOINT2 connects?
Can I connect it to an element with property=solid and material=rigid?
Tnx,
Doobie
1 - 4 of 41
    Altair Employee
    OP
    Hi Doobie,
    KJOINT2 is used for spring elements. This tool will create automatically the needed rigid bodies and also property card in accordance to the selected type of joint.
    Thank you
    Altair Employee
    OP
    thanks for you answer, however, i wish to know to what type of rigid bodies and elements I can connect this type of element
    Altair Employee
    OP
    Hi Doobie,
    You can connect with RBODY master node for example.
    Altair Employee
    OP
    Hi Doobie
    In Radioss it is recommended not to use the M13_RIGID.
    Yes you can create a KJOINT2 between two components with solid elements. Just ensure that all the nodes of the solid components you are connecting are rigid, by defining a /RBODY for each of them.
    Also it is recommended to have the two nodes of the spring defining the /KJOINT2, to be coincident.
