How to measure volume,area and mass using tcl
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
 How to measure volume,area and mass using tcl. In hypermesh by Tools --> mass calc..
I need to change the density to adjust the mass of a component. For that i need the volume of the component.
how to measure that using tcl...
1 - 9 of 91
    User: "tinh"
    Altair Community Member
    Updated by tinh
    if you need only volume:
    *createmark comps 1 $compid
    hm_volume comps 1
    Altair Employee
    OP
    Thanks for the reply!!
    How to get min/max values of nodes,elements,components??
    For Max value i found 'hm_entitymaxsolverid comps'
    For Min value ??
    User: "tinh"
    Updated by tinh
    ^.^ altair not provide command for min solverid ???
    using hm_entitylist get list of i-IDs then convert to s-IDs
    sort s-IDs list then you get minimum value
    or : push panel 'renumber' => *createmark entity 1 all => hm_activateitem 'min/max' => hm_getmessage
    Altair Employee
    OP
    Thanks for the Reply!!
    But, i tried both i did't get the results..
    set i 0
    *createmark elems 1 all
    set elemList [hm_getlist elems 1]
    set elemMin [lindex $elemList $i]
    puts -nonewline $fileId $elemMin
    when i print the 'elemMin' nothing is there
    i want to print the mininmum id's of nodes,elements,materials,systems and system collectors in a file...
    And one more thing is i tried to deletemodel for importing new file...
    I tried
    *deletemodel
    *deletemodel 1
    *deletemodel
    *answer yes
    wen i run this it is asking the user to select yes or no...
    Help me on this!!!
    User: "tinh"
    Updated by tinh
    hi,
    to get elemList selected on mark 1: hm_getmark elems 1    (not 'hm_getlist')
    to ignore hm asking 'yes/no':
    hm_answernext yes
    *deletemodel
    Altair Employee
    OP
    Thanks for the reply!!!
    It worked..
    Altair Employee
    OP
    How to measure mass using the tcl?
    *createmark elements 1 displayed
    for this mark i need to get the mass value....
    User: "tinh"
    Updated by tinh
    hi,
    there is no 'hm_mass elems 1 ' available to get mass
    but make it your self
    just take volume and multiply by density value in material card
    Altair Employee
    OP
    Actually it is available.
    set mascalc [hm_getmass elems 1]
    Mass       =    set mas [lindex $mascalc 0]
    Volume    =    set vol [lindex $mascalc 1]
    Area        =    set are [lindex $mascalc 2]
