Altair RISE
Nominate Yourself Now!
Alingned Node Coordinate Value (TCL Script)
User: "Felipe Cunha1"
Altair Community Member
Updated by Felipe Cunha1
Hi,
How can I determine the node coordinates aligned from two nodes without need to use a temporary node technique.
A function type:
Input1:   two nodes N1 and N2    ( For Vector Definition)
Input2:   Node   N3  ( To be projected perpendicularly  to N1 and N2 vector )
output:  Aligned N3     (New Coordinate  ==>  X,Y and Z )
Thanks in Advance,
Felipe
1 - 7 of 71
    User: "tinh"
    Updated by tinh
    Hi
    I don't remember transforming matrix. But use vectors to find V04:
    (N4 is projected of N3)
    <?xml version="1.0" encoding="UTF-8"?>20190612_101312.thumb.jpg.11e1f9ab9cf2e9777086865282d49a16.jpg
    From V13 you can utilize built-in package math::linearalgebra
    <?xml version="1.0" encoding="UTF-8"?>20190612_101802.thumb.jpg.1c741f46ed956fc016fe83879ddb0147.jpg
    OP
    Hi Tinh,
    I really appreciated your code, but unfortunately HM could not found the ::math::linearalgebra package. It is possible be installed our use an similar  hypermesh library?
    Thanks,
    Felipe
    OP
    Hi Tinh,
    I found a similar functions in hypermesh:
    ::hwat::math::VectorCrossProduct {vector1} {vector2}
    ::hwat::math::VectorNormalize {valuelist} normvalue
    It solved now.
    Thanks very much!
    Felipe
    User: "tinh"
    Updated by tinh
    Even if there is no available function, you can write them easily. Google for their formula.
    User: "tinh"
    Updated by tinh
    An example expanse usage of expr command to do vector operations:
    <?xml version="1.0" encoding="UTF-8"?>20190613_085919.thumb.jpg.3584f7f5a8818834824fa4e2c5e1f968.jpg
    User: "Manoj Yandra"
    Updated by Manoj Yandra
    I want to get the coordinates of a node and use it in defining the base point (while projecting). Can you please tell me how to do this?
    User: "tinh"
    Updated by tinh
    Try
    set coords [ join [hm_nodevalue $nid]]
