🎉Community Raffle - Win $25
Join and Win
MotionView mdl-file CANNOT BE CONVERTED to MotionSolve xml-file
User: "Filippo Marinelli"
Altair Community Member
Updated by Filippo Marinelli
Dear all,
I am joining the Altair Digital twin contest, in which many Altair products have to be used.
In particular, when I run the simulation example (task B) Altair Activate fails the completion because of an error.
The error is shown in the image below.
I've checked the license: everything is ok, the physical address ok, the environmental variable path ok, the license location ok. It seems a problem related to the HyperWorks sw.
How can I check the MotionView installation? I mean, I have installed the HyperWork sw: edu2021_win64 download. Do I need something other?
Thank you for the attention.
Best regards to all of you guys, Filippo.
1 - 8 of 81
    User: "AnanthK"
    Altair Employee
    Updated by AnanthK
    Hello Filippo - Please make sure you have the following packages installed. Open MotionView from the windows menu, go to Help -> Updates & system information, then verify that you have:
    Altair Home: C:/Program Files/Altair/2021/hwdesktop
    Updates Information:
    AltairActivate2021
    AltairCompose2021
    hwDesktop2021
    hwDesktopHelp2021
    hwSolvers2021
    hwSolversHelp2021
    If you cannot open Motionview, then you don't actually have Hyperworks installed. Please contact your local Altair support for download and install instructions specific to EDU, and your country.
    Thanks,
    Ananth
    OP
    AltairActivate2021
    AltairCompose2021
    hwDesktop2021
    hwDesktopHelp2021
    hwSolvers2021
    hwSolversHelp2021
    Thanks,
    Ananth
    Hi,
    as you guessed, I hadn't installed MotionView. Now I did, and I have everything correctly configured as you have indicated.
    However, when I run the same simulation, I still get the same error:
    'MotionView mdl-file cannot be converted into MotionSolve XML-file'
    I don't really know what this can be due to.
    Thank you all for help
    OP
    Hi,
    User: "SouravDas0306"
    Altair Employee
    Updated by SouravDas0306
    Hello Filippo,
    You must set up a system variable if possible, the below image shows a user variable.
    In case you cannot browse to file you should copy and paste the full path of the license file location including the file name in the value field.
    For eg: C:\Program Files\Altair\2021-edu\security\altair_lic.da
    Regards,
    Sourav
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    @Filippo Marinelli
    It appears you have not set the paths as mentioned here - https://community.altair.com/community?id=community_question&sys_id=63fdc4dddb766410cfd5f6a4e2961967
    This is mentioned and there is a link to this post on the contest page as well
    Let us know if this helped you solve the error
    OP
    Dear @Rahul Ponginan and @Sourav Das , I checked everything you have suggested, both path and environmental variables.
    Now something happens, but, unfortunately, I do see another error:image
    And the alarm window is:
    'Unable to load MotionSolve interface dll during block initialization, please read the logfile
    Do you know something about this error?
    Thank you really much for your help
    User: "João Marabisa"
    Altair Employee
    Updated by João Marabisa
    Hi Filippo,
    It looks like that the problem happens when Activate tries to access binaries files on MotionView/MotionSolve path.
    Please execute these 2 commands below on Activate command window, then access the two folders to see is they really don't have binaries files there (I have done it now and I have found the file that is on your error message):
    GetMotionSolveBinDirectory()
    GetMotionViewBinDirectory()
    I suspect that the installation file has corrupted (either Activate or Motion, or even both).
    I'd like to ask you another test: Please execute any co-simulation model on Tutorials and see if it can be executed without errors:
    Regards.
    User: "Maor Kletter_22156"
    New Altair Community Member
    Updated by Maor Kletter_22156
    Hi Filippo,
    Regards.
    Hey João Marabisa,
    I have tried to use FMU in Simulink of Matlab to make co-simulation with motion-solve and encountered with a problm with the same binari file you mentioned in that comment "mscicos.dll".
    According my simulink error log there is a problem load mscicos.dll while running.
    What Can I do to solve that?
