once the xyz procedure has been executed ,the yellow button should change in some other color.
Hello,
Use the below command inside 'xyz' procedure. .mainWindow.mainWindowForRow2.but_Browse3 configure -background red
Hello, Use the below command inside 'xyz' procedure. .mainWindow.mainWindowForRow2.but_Browse3 configure -background red
thanks Livil..its working..:)
Hello,
