Solid Map Errors
I am attempting to mesh a complex part. I was able to split the entirety of the part into a total of 38 mappable sub-parts. When I highlight the entirety of the model and click mesh, my screen says "incomplete sequenced 1/38 solids with 274/0 edge grps" and then "Meshing Failed". How do I stop this from happening?
1 - 1 of
11
I have created a Service ticket for your request as this may need some investigation.
May i know which version are you using ?
Also could you please share the split model with us to investigate.
