🎉Community Raffle - Win $25
Join and Win
Is it possible to use EDEMpy to see the contour of a coordination number?
Hello, everyone.
I'm looking for the coordination number contour in the simulated domain.
Could you please advise me in this matter?
Regards,
Fatemeh
1 - 1 of 11
    Hi Fatemeh,
    It is possible to compute the particle coordination numbers from the surface to surface contacts data with EDEMpy (take a look at the edempy.timestep.SSContact module) but it might be easier to directly export the data from EDEM along with particle positions and produce a contour from those using matplotlib surf3D,  myavi or similar.
    To export the data go to EDEM Analyst->File->Export and create queries for the attributes shown below:
    You can also directly colour the particles by coordination number:
    Best regards,
    Stefan
