🎉Community Raffle - Win $25
Join and Win
Angle between two lines
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
How to measure angle between two lines in Hypermesh?
1 - 5 of 51
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Firstly, do you know how to measure on paper?
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Hello,
    In the 'Geom' page go to 'Distance' panel. Using the three nodes option select the three nodes of the two line between which you want to measure the angle. This will automatically give you the angle between the two lines.
    Please refer below image.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.2e031ab8730fc153d5450e4ea2e1048e.png
    Thankyou
    Hello,
    Thankyou
    Could you see the difference the angle forming from '3 nodes' and from '2 arbitrary lines'?
    When I say 'angle between 2 lines', I would like to speak about 2  arbitrary lines in space, not your special case where 2 lines forming from 3 nodes.
    Two arbitrary lines can mean anything. They can be in different planes or any other special case. In that situation the above solution is not possible. That requires a combination of HM as well as some hand calculations.
    The above shown method will only work when the two lines meet at a point.
    Please specify in what respect do you want to measure the angle.
    Thankyou
    Mathematically, just compute dot product of two vectors.
