🎉Community Raffle - Win $25
Join and Win
Unit conversion
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I am scaling my model from mm to meter units. I am able to scale down the elements but the thickness in the PSHELL remain unchanged. they are still in mm units. How do I scale the entire model along with the thickness and material properties also.
Thanks in advance
1 - 1 of 11
    Altair Employee
    OP
    Hi Mithun,
    Scale option can only be used to increase or decrease an entity’s dimensions. The material parameters and property parameters has to modified manually.
    But a script is available for the same at https://connect.altair.com/CP/script-list.html  . Please try with the same.
