Shell thickness
Hi all,
How to get shell thickness that is defined in the shell property through
hm_getvalue property id=1 dataname=136
But I need to use attributename of the attribute id 136
to find the name if I use hm_attributenamefromid 136
it gives the list name where real constants are defined.
Can anyone help with this.
Thanks,
mahes
It's better to use hm_getthickness comps $compid
So you don't need to handle attribs ids or names
