🎉Community Raffle - Win $25
Join and Win
TCL script with http under Hypermesh
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I have a simple script :
package require http;
set myurl 'http://mysite/file.txt';
proc getPage { url } {
set token [::http::geturl $url]
set data [::http::data $token]
::http::cleanup $token
return $data
set file [ getPage $myurl ]
puts '$file'
With TCL 8.5 under Windows 7, I can run this script without problem.
But when I try to run under Hypermesh session (via : source ....) I got error message :
Main console display active (Tcl8.5.9 / Tk8.5.9)
(hw13) 1 % source C:/Users/MYNAME/test.tcl
couldn't open socket: invalid argument
I don't know why this script does not work under Hypermesh.
Any idea for help ?
Thanks,
UPDATE: it works well when I try command line within cmd window:
'C:\Program Files\Altair\13.0\hw\tcl\tcl8.5.9\win64\bin\tclsh85.exe' test.tcl
1 - 8 of 81
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi Mr Quy
    I try with hm12 and it worked
    Altair Employee
    OP
    Hi Mr Quy
    Really? I have removed HM12 some month ago.
    I'm waiting for release 14 now.
    User: "Merula_20758"
    Updated by Merula_20758
    I tried it both in 12 and 13 and neither of them works for me... same error in 12.
    Also tried it with adminstator rights... no success. But I still think its some permisson error....
    Best regards,
    Merula
    Altair Employee
    OP
    WORKAROUND: the same task is written by Perl. From TCL, use 'exec ...'.
    Altair Employee
    OP
    Hello I'm getting this error stating 'Main console display active (Tcl8.5.9 / Tk8.5.9)
    (Documents) 1 % '
    User: "tinh"
    Updated by tinh
    (Documents) 1 % '
    It is not error message. It is headlines of tkconsole
    User: "Abdul Muizz Jamal"
    Updated by Abdul Muizz Jamal
    (Documents) 1 % '
    But how to remove it?? I can't open the Countours Tab to view the results. I am having this same issue
    User: "BenGoba"
    Updated by BenGoba
    We've had luck with the Windows 'start' command to load Word files and URLs from within the HyperMesh TCL environment.  If you are still facing the issue, you can try something similar to:
    exec cmd /c start "https://altair.com"
    Hopefully letting Windows handle opening the page will work better.
