🎉Community Raffle - Win $25
Join and Win
Distributed Forces and Moments
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi, i'm new to HyperWorks (and to FEA in general) and i have a couple of questions.
I want to run an optimization for a pulley, and i am having problems when applying distributed forces and moments.
Is it possible to apply a distributed force over a surface without using pressure?
Is it possibe to apply distributed moments over a surface in HyperMesh? How do i do it?
Thanks.
Thanks for the answer, i used rigid elements, and i got good results.
1 - 1 of 11
    Altair Employee
    OP
    I would use an RBE to distribute the load among the nodes in the area you are interested. If you want to enforce a specific load at each node, then simply divide the load over evenly distributed nodes.
