Composite optimization
Hello there,
I'm trying to do a composite optimization whose objective is to minimize mass. I'd like to set as optimization contraint the composite failure accroding to the Tsai-Wu theory (so that the solver should minimize but still granting the composite resistance).
I followed the tutorials, I couldn't find anyone that used such constraint... I tried to figure it out by myself, but I didn't get satisfying results... Can anybody help me please?
Thank you
Hello,
For the analysis I used a laminate made up by plies of different orientations (45°, 90°, 0°, -45° and -90°). I used a PCOMPP property and set TSAI under the [FT] panel. The analysis ran without problems and the composite failure results are less than 1 for each ply (I suppose this means that the resistance is granted for each ply).
Then I turned to optimization. As objective I set the mass minimization, while as constraint i used a 'composite failure' response and I set the upper bound to 0.8 (supposing that 1 meant failure, according to Tsai-Wu criterion). So my aim is to reduce the mass of the laminate but still granting a resistance margin.
The optimization runs, but it only consists in one iteration and the main result is something like that:
2 CFAIL res_stre 1 8280 TSAI 4.926E-01 < 8.000E-01 0.0
P1
2 CFAIL res_stre 1 8510 TSAI 4.925E-01 < 8.000E-01 0.0
P1
2 CFAIL res_stre 1 8511 TSAI 4.838E-01 < 8.000E-01 0.0
P1
Can you please tell which are my mistakes? Thank you
Hello
I think I found out why I can't make on optimization using the 'composite failure' as constraint.
When the optimization starts, this message is displayed:
NO DESIGN MATERIAL OR DESIGN VARIABLES FOUND : ANALYSIS ONLY
And this is strange, since I have indeed created a design variable before (in particular I created a 'composite size desvar', which allowed me to use the 'composite failure' as constraint).
So it's like if the solver couldn't see my design variable...
Can you help me please?
Thank you
Hi Fede54
could you please elaborate what have you tried?
What is the composite failure result for Analysis only?
