I want to know material property of CFRP
HI,
I would like to know the properties of the composite material consisting of epoxy(40%) and carbon fiber(60%) with these properties.
| specimen | |
Epoxy (Resoltech 1800) | CF (Toray T700) | |
r (g/cm3) | 1.10-1.12 | 1.8 |
E1 (MPa) | 2703-3708 | 230000 |
E2 (MPa) | E1 | 29273* |
E3 (MPa) | E1 | E2 |
G (MPa) | 2746.7* | 25091* |
n12 | 0.35* | 0.25* |
n31 | n12 | 0.0318* |
n23 | n12 | 0.2* |
Stacking the carbon fiber angle of 0 ° 45 ° 90 ° -45 -45 90 ° 45 ° 0 ° to make a CFRP..
And to obtain the properties for MAT25 type (in Radioss) of CFRP.
Material properties for MAT25 are Rho_Initial, E11, E22, E33, Nu_12, Iflag, G12, G23, G31, EPS_t1, EPS_m1, EPS_t2, EPS_m2, Wp_max, Ioff, Ratio, SIG1_yt, b1_t, n1_t, SIG1max_t, SIG2_yt, b2_t, n2_t, SIG2max_t, SIG1_yc, b1_c, n1_c, SIG1max_c, EPS1_c1, EPS2_c1, SIG2_yc, b2_c, n2_c, SIG2max_c, EPS1_c2, EPS2_c2, SIG12_yt, b12_t, n12_t, SIG12max_t.
Please show me how to know this properties.
Hi @domado
I am not sure what exactly you would like to know. If you are looking for material properties, please contact the supplier for the same.
