How to reset selected variables in TCL
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hie everybody
When I loop over several subcases to post treat the stresses, I need to reset variables otherwise, the results , I can obtain in the first loop, remain in the next loops : thus it is impossible to get the results I want.
I tried to use the command : 'namespace delete varaible' but it deletes all
thanks for your replies
greg
1 - 2 of 21
    Altair Employee
    OP
    HI,
    You can loop again and unset pertcular variable instead of deleting whole namespace.
    Altair Employee
    OP
    # console.tcl --
    # This code constructs the console window for an application. It
    # can be used by non-unix systems that do not have built-in support
    # for shells.
    # RCS: @(#) $Id: console.tcl,v 1.22.2.3 2005/05/31 04:58:00 hobbs Exp $
    # Copyright © 1995-1997 Sun Microsystems, Inc.
    # Copyright © 1998-2000 Ajuba Solutions.
    # See the file 'license.terms' for information on usage and redistribution
    # of this file, and for a DISCLAIMER OF ALL WARRANTIES.
    # TODO: history - remember partially written command
    namespace eval ::tk::console {
    variable blinkTime 500 ; # msecs to blink braced range for
    variable blinkRange 1 ; # enable blinking of the entire braced range
    variable magicKeys 1 ; # enable brace matching and proc/var recognition
    variable maxLines 600 ; # maximum # of lines buffered in console
    variable showMatches 1 ; # show multiple expand matches
    variable inPlugin [info exists embed_args]
    variable defaultPrompt ; # default prompt if tcl_prompt1 isn't used
    if {$inPlugin} {
    set defaultPrompt {subst {[history nextid] % }}
    } else {
    set defaultPrompt {subst {([file tail [pwd]]) [history nextid] % }}
    # simple compat function for tkcon code added for this console
    interp alias {} EvalAttached {} consoleinterp eval
    # ::tk::ConsoleInit --
    # This procedure constructs and configures the console windows.
    # Arguments:
    # None.
    proc ::tk::ConsoleInit {} {
    global tcl_platform
    if {![consoleinterp eval {set tcl_interactive}]} {
    wm withdraw .
    if {[string equal $tcl_platform(platform) 'macintosh']
    || [string equal [tk windowingsystem] 'aqua']} {
    set mod 'Cmd'
    } else {
    set mod 'Ctrl'
    if {[catch {menu .menubar} err]} { bgerror 'INIT: $err' }
    .menubar add cascade -label File -menu .menubar.file -underline 0
    .menubar add cascade -label Edit -menu .menubar.edit -underline 0
    menu .menubar.file -tearoff 0
    .menubar.file add command -label [mc 'Source...'] \
    -underline 0 -command tk::ConsoleSource
    .menubar.file add command -label [mc 'Hide Console'] \
    -underline 0 -command {wm withdraw .}
    .menubar.file add command -label [mc 'Clear Console'] \
    -underline 0 -command {.console delete 1.0 'promptEnd linestart'}
    .menubar.file add command -label [mc 'Quit'] \
    -command exit -accel Cmd-Q
    } else {
    .menubar.file add command -label [mc 'Exit'] \
    -underline 1 -command exit
    menu .menubar.edit -tearoff 0
    .menubar.edit add command -label [mc 'Cut'] -underline 2 \
    -command { event generate .console <<Cut>> } -accel '$mod+X'
    .menubar.edit add command -label [mc 'Copy'] -underline 0 \
    -command { event generate .console <<Copy>> } -accel '$mod+C'
    .menubar.edit add command -label [mc 'Paste'] -underline 1 \
    -command { event generate .console <<Paste>> } -accel '$mod+V'
    if {[string compare $tcl_platform(platform) 'windows']} {
    .menubar.edit add command -label [mc 'Clear'] -underline 2 \
    -command { event generate .console <<Clear>> }
    } else {
    .menubar.edit add command -label [mc 'Delete'] -underline 0 \
    -command { event generate .console <<Clear>> } -accel 'Del'
    .menubar add cascade -label Help -menu .menubar.help -underline 0
    menu .menubar.help -tearoff 0
    .menubar.help add command -label [mc 'About...'] \
    -underline 0 -command tk::ConsoleAbout
    . configure -menu .menubar
    set con [text .console -yscrollcommand [list .sb set] -setgrid true]
    scrollbar .sb -command [list $con yview]
    pack .sb -side right -fill both
    pack $con -fill both -expand 1 -side left
    switch -exact $tcl_platform(platform) {
    'macintosh' {
    $con configure -font {Monaco 9 normal} -highlightthickness 0
    'windows' {
    $con configure -font systemfixed
    'unix' {
    if {[string equal [tk windowingsystem] 'aqua']} {
    #added for right click menu
    if {[catch {menu .cutPasteMenu -tearoff 0 -type normal} err]} { bgerror 'INIT: $err' }
    # .cutPasteMenu add command -label [mc 'Cut'] -underline 2 \
    # -command { event generate .console <<Cut>> } -accel '$mod+X'
    .cutPasteMenu add command -label [mc 'Copy'] -underline 0 \
    .cutPasteMenu add command -label [mc 'Paste'] -underline 1 \
    # .cutPasteMenu add command -label [mc 'Clear'] -underline 2 \
    # -command { event generate .console <<Clear>> }
    ConsoleBind $con
    $con tag configure stderr -foreground red
    $con tag configure stdin -foreground blue
    $con tag configure prompt -foreground \#8F4433
    $con tag configure proc -foreground \#008800
    $con tag configure var -background \#FFC0D0
    $con tag raise sel
    $con tag configure blink -background \#FFFF00
    $con tag configure find -background \#FFFF00
    focus $con
    # changed this so as not to leave a wish.exe left running
    wm protocol . WM_DELETE_WINDOW {
    if {[wm state .]=='normal'} {
    # destroy .
    exit
    } else {
    wm withdraw .
    wm title . [mc 'Console']
    flush stdout
    $con mark set output [$con index 'end - 1 char']
    tk::TextSetCursor $con end
    $con mark set promptEnd insert
    $con mark gravity promptEnd left
    # this is the binding that pops the menu
    # and additionally enables/disables the copy function
    # based on if you have selected any data
    bind all <Button-3> {
    .cutPasteMenu entryconfigure 0 -state normal
    if {[catch {%W get sel.first sel.last}]} {
    .cutPasteMenu entryconfigure 0 -state disabled
    tk_popup .cutPasteMenu [winfo pointerx %W] [winfo pointery %W]
    # A variant of ConsolePrompt to avoid a 'puts' call
    set w $con
    set temp [$w index 'end - 1 char']
    $w mark set output end
    if {![consoleinterp eval 'info exists tcl_prompt1']} {
    set string [EvalAttached $::tk::console::defaultPrompt]
    $w insert output $string stdout
    $w mark set output $temp
    ::tk::TextSetCursor $w end
    $w mark set promptEnd insert
    $w mark gravity promptEnd left
    if {$tcl_platform(platform) eq 'windows'} {
    # Subtle work-around to erase the '% ' that tclMain.c prints out
    after idle [list $con delete 1.0 output]
    # ::tk::ConsoleSource --
    # Prompts the user for a file to source in the main interpreter.
    # Arguments:
    # None.
    proc ::tk::ConsoleSource {} {
    set filename [tk_getOpenFile -defaultextension .tcl -parent . \
    -title [mc 'Select a file to source'] \
    -filetypes [list \
    [list [mc 'Tcl Scripts'] .tcl] \
    [list [mc 'All Files'] *]]]
    if {[string compare $filename '']} {
    set cmd [list source $filename]
    if {[catch {consoleinterp eval $cmd} result]} {
    ConsoleOutput stderr '$result\n'
    # ::tk::ConsoleInvoke --
    # Processes the command line input. If the command is complete it
    # is evaled in the main interpreter. Otherwise, the continuation
    # prompt is added and more input may be added.
    # Arguments:
    # None.
    proc ::tk::ConsoleInvoke {args} {
    set ranges [.console tag ranges input]
    set cmd ''
    if {[llength $ranges]} {
    set pos 0
    while {[string compare [lindex $ranges $pos] '']} {
    set start [lindex $ranges $pos]
    set end [lindex $ranges [incr pos]]
    append cmd [.console get $start $end]
    incr pos
    if {[string equal $cmd '']} {
    ConsolePrompt
    } elseif {[info complete $cmd]} {
    .console mark set output end
    .console tag delete input
    set result [consoleinterp record $cmd]
    if {[string compare $result '']} {
    puts $result
    ConsoleHistory reset
    ConsolePrompt
    } else {
    ConsolePrompt partial
    .console yview -pickplace insert
    # ::tk::ConsoleHistory --
    # This procedure implements command line history for the
    # console. In general is evals the history command in the
    # main interpreter to obtain the history. The variable
    # ::tk::HistNum is used to store the current location in the history.
    # Arguments:
    # cmd - Which action to take: prev, next, reset.
    set ::tk::HistNum 1
    proc ::tk::ConsoleHistory {cmd} {
    variable HistNum
    switch $cmd {
    prev {
    incr HistNum -1
    if {$HistNum == 0} {
    set cmd {history event [expr {[history nextid] -1}]}
    } else {
    set cmd 'history event $HistNum'
    if {[catch {consoleinterp eval $cmd} cmd]} {
    incr HistNum
    return
    .console delete promptEnd end
    .console insert promptEnd $cmd {input stdin}
    next {
    incr HistNum
    } elseif {$HistNum > 0} {
    set cmd ''
    set HistNum 1
    } else {
    if {[string compare $cmd '']} {
    reset {
    set HistNum 1
    # ::tk::ConsolePrompt --
    # This procedure draws the prompt. If tcl_prompt1 or tcl_prompt2
    # exists in the main interpreter it will be called to generate the
    # prompt. Otherwise, a hard coded default prompt is printed.
    # Arguments:
    # partial - Flag to specify which prompt to print.
    proc ::tk::ConsolePrompt {{partial normal}} {
    set w .console
    if {[string equal $partial 'normal']} {
    if {[consoleinterp eval 'info exists tcl_prompt1']} {
    consoleinterp eval 'eval \[set tcl_prompt1\]'
    } else {
    puts -nonewline [EvalAttached $::tk::console::defaultPrompt]
    } else {
    set temp [$w index output]
    if {[consoleinterp eval 'info exists tcl_prompt2']} {
    consoleinterp eval 'eval \[set tcl_prompt2\]'
    } else {
    puts -nonewline '> '
    flush stdout
    ::tk::console::ConstrainBuffer $w $::tk::console::maxLines
    $w see end
    # ::tk::ConsoleBind --
    # This procedure first ensures that the default bindings for the Text
    # class have been defined. Then certain bindings are overridden for
    # the class.
    # Arguments:
    # None.
    proc ::tk::ConsoleBind {w} {
    bindtags $w [list $w Console PostConsole [winfo toplevel $w] all]
    ## Get all Text bindings into Console
    foreach ev [bind Text] { bind Console $ev [bind Text $ev] }
    ## We really didn't want the newline insertion...
    bind Console <Control-Key-o> {}
    ## ...or any Control-v binding (would block <<Paste>>)
    bind Console <Control-Key-v> {}
    # For the moment, transpose isn't enabled until the console
    # gets and overhaul of how it handles input -- hobbs
    bind Console <Control-Key-t> {}
    # Ignore all Alt, Meta, and Control keypresses unless explicitly bound.
    # Otherwise, if a widget binding for one of these is defined, the
    bind Console <Alt-KeyPress> {# nothing }
    bind Console <Meta-KeyPress> {# nothing}
    bind Console <Control-KeyPress> {# nothing}
    foreach {ev key} {
    <<Console_Prev>> <Key-Up>
    <<Console_Next>> <Key-Down>
    <<Console_NextImmediate>> <Control-Key-n>
    <<Console_PrevImmediate>> <Control-Key-p>
    <<Console_PrevSearch>> <Control-Key-r>
    <<Console_NextSearch>> <Control-Key-s>
    <<Console_Expand>> <Key-Tab>
    <<Console_Expand>> <Key-Escape>
    <<Console_ExpandFile>> <Control-Shift-Key-F>
    <<Console_ExpandProc>> <Control-Shift-Key-P>
    <<Console_ExpandVar>> <Control-Shift-Key-V>
    <<Console_Tab>> <Control-Key-i>
    <<Console_Tab>> <Meta-Key-i>
    <<Console_Eval>> <Key-Return>
    <<Console_Eval>> <Key-KP_Enter>
    <<Console_Clear>> <Control-Key-l>
    <<Console_KillLine>> <Control-Key-k>
    <<Console_Transpose>> <Control-Key-t>
    <<Console_ClearLine>> <Control-Key-u>
    <<Console_SaveCommand>> <Control-Key-z>
    event add $ev $key
    bind Console $key {}
    bind Console <<Console_Expand>> {
    if {[%W compare insert > promptEnd]} {::tk::console::Expand %W}
    bind Console <<Console_ExpandFile>> {
    if {[%W compare insert > promptEnd]} {::tk::console::Expand %W path}
    bind Console <<Console_ExpandProc>> {
    if {[%W compare insert > promptEnd]} {::tk::console::Expand %W proc}
    bind Console <<Console_ExpandVar>> {
    if {[%W compare insert > promptEnd]} {::tk::console::Expand %W var}
    bind Console <<Console_Eval>> {
    %W mark set insert {end - 1c}
    tk::ConsoleInsert %W '\n'
    tk::ConsoleInvoke
    break
    bind Console <Delete> {
    if {[string compare {} [%W tag nextrange sel 1.0 end]] \
    && [%W compare sel.first >= promptEnd]} {
    %W delete sel.first sel.last
    } elseif {[%W compare insert >= promptEnd]} {
    %W delete insert
    %W see insert
    bind Console <BackSpace> {
    } elseif {[%W compare insert != 1.0] && \
    %W delete insert-1c
    %W see insert
    bind Console <Control-h> [bind Console <BackSpace>]
    bind Console <Home> {
    if {[%W compare insert < promptEnd]} {
    tk::TextSetCursor %W {insert linestart}
    } else {
    tk::TextSetCursor %W promptEnd
    bind Console <Control-a> [bind Console <Home>]
    bind Console <End> {
    tk::TextSetCursor %W {insert lineend}
    bind Console <Control-e> [bind Console <End>]
    bind Console <Control-d> {
    if {[%W compare insert < promptEnd]} break
    %W delete insert
    bind Console <<Console_KillLine>> {
    if {[%W compare insert == {insert lineend}]} {
    %W delete insert
    } else {
    %W delete insert {insert lineend}
    bind Console <<Console_Clear>> {
    ## Clear console display
    %W delete 1.0 'promptEnd linestart'
    bind Console <<Console_ClearLine>> {
    ## Clear command line (Unix shell staple)
    %W delete promptEnd end
    bind Console <Meta-d> {
    %W delete insert {insert wordend}
    bind Console <Meta-BackSpace> {
    if {[%W compare {insert -1c wordstart} >= promptEnd]} {
    %W delete {insert -1c wordstart} insert
    bind Console <Meta-Delete> {
    bind Console <<Console_Prev>> {
    tk::ConsoleHistory prev
    bind Console <<Console_Next>> {
    tk::ConsoleHistory next
    bind Console <Insert> {
    catch {tk::ConsoleInsert %W [::tk::GetSelection %W PRIMARY]}
    bind Console <KeyPress> {
    tk::ConsoleInsert %W %A
    bind Console <F9> {
    eval destroy [winfo child .]
    if {[string equal $tcl_platform(platform) 'macintosh']} {
    if {[catch {source [file join $tk_library console.tcl]}]} {source -rsrc console}
    } else {
    if {[string equal $::tcl_platform(platform) 'macintosh']
    bind Console <Command-q> {
    exit
    bind Console <<Cut>> {
    # Same as the copy event
    clipboard clear -displayof %W
    if {![catch {set data [%W get sel.first sel.last]}]} {
    clipboard append -displayof %W $data
    bind Console <<Copy>> {
    bind Console <<Paste>> {
    catch {
    set clip [::tk::GetSelection %W CLIPBOARD]
    set list [split $clip \n\r]
    tk::ConsoleInsert %W [lindex $list 0]
    foreach x [lrange $list 1 end] {
    tk::ConsoleInvoke
    tk::ConsoleInsert %W $x
    ## Bindings for doing special things based on certain keys
    bind PostConsole <Key-parenright> {
    if {[string compare \\ [%W get insert-2c]]} {
    ::tk::console::MatchPair %W \( \) promptEnd
    bind PostConsole <Key-bracketright> {
    ::tk::console::MatchPair %W \[ \] promptEnd
    bind PostConsole <Key-braceright> {
    ::tk::console::MatchPair %W \{ \} promptEnd
    bind PostConsole <Key-quotedbl> {
    ::tk::console::MatchQuote %W promptEnd
    bind PostConsole <KeyPress> {
    if {'%A' != ''} {
    ::tk::console::TagProc %W
    break
    # ::tk::ConsoleInsert --
    # Insert a string into a text at the point of the insertion cursor.
    # If there is a selection in the text, and it covers the point of the
    # insertion cursor, then delete the selection before inserting. Insertion
    # is restricted to the prompt area.
    # Arguments:
    # w - The text window in which to insert the string
    # s - The string to insert (usually just a single character)
    proc ::tk::ConsoleInsert {w s} {
    if {[string equal $s '']} {
    return
    catch {
    if {[$w compare sel.first <= insert]
    && [$w compare sel.last >= insert]} {
    $w tag remove sel sel.first promptEnd
    $w delete sel.first sel.last
    if {[$w compare insert < promptEnd]} {
    $w mark set insert end
    $w insert insert $s {input stdin}
    $w see insert
    # ::tk::ConsoleOutput --
    # This routine is called directly by ConsolePutsCmd to cause a string
    # to be displayed in the console.
    # Arguments:
    # dest - The output tag to be used: either 'stderr' or 'stdout'.
    # string - The string to be displayed.
    proc ::tk::ConsoleOutput {dest string} {
    set w .console
    $w insert output $string $dest
    $w see insert
    # ::tk::ConsoleExit --
    # This routine is called by ConsoleEventProc when the main window of
    # the application is destroyed. Don't call exit - that probably already
    # happened. Just delete our window.
    # Arguments:
    # None.
    proc ::tk::ConsoleExit {} {
    destroy .
    # ::tk::ConsoleAbout --
    # This routine displays an About box to show Tcl/Tk version info.
    # Arguments:
    # None.
    proc ::tk::ConsoleAbout {} {
    tk_messageBox -type ok -message '[mc {Tcl for Windows}]
    Tcl $::tcl_patchLevel
    Tk $::tk_patchLevel'
    # ::tk::console::TagProc --
    # Tags a procedure in the console if it's recognized
    # This procedure is not perfect. However, making it perfect wastes
    # too much CPU time...
    # Arguments:
    # w - console text widget
    proc ::tk::console::TagProc w {
    if {!$::tk::console::magicKeys} { return }
    set exp '\[^\\\\\]\[\[ \t\n\r\;{}\'\$\]'
    set i [$w search -backwards -regexp $exp insert-1c promptEnd-1c]
    if {$i == ''} {set i promptEnd} else {append i +2c}
    regsub -all '\[\[\\\\\\?\\*\]' [$w get $i 'insert-1c wordend'] {\\\0} c
    if {[llength [EvalAttached [list info commands $c]]]} {
    $w tag add proc $i 'insert-1c wordend'
    } else {
    $w tag remove proc $i 'insert-1c wordend'
    if {[llength [EvalAttached [list info vars $c]]]} {
    $w tag add var $i 'insert-1c wordend'
    } else {
    $w tag remove var $i 'insert-1c wordend'
    # ::tk::console::MatchPair --
    # Blinks a matching pair of characters
    # c2 is assumed to be at the text index 'insert'.
    # This proc is really loopy and took me an hour to figure out given
    # all possible combinations with escaping except for escaped \'s.
    # It doesn't take into account possible commenting... Oh well. If
    # anyone has something better, I'd like to see/use it. This is really
    # only efficient for small contexts.
    # Arguments:
    # c1 - first char of pair
    # c2 - second char of pair
    # Calls: ::tk::console::Blink
    proc ::tk::console::MatchPair {w c1 c2 {lim 1.0}} {
    if {[string compare {} [set ix [$w search -back $c1 insert $lim]]]} {
    while {
    [string match {\\} [$w get $ix-1c]] &&
    [string compare {} [set ix [$w search -back $c1 $ix-1c $lim]]]
    set i1 insert-1c
    while {[string compare {} $ix]} {
    set i0 $ix
    set j 0
    while {[string compare {} [set i0 [$w search $c2 $i0 $i1]]]} {
    append i0 +1c
    if {[string match {\\} [$w get $i0-2c]]} continue
    incr j
    if {!$j} break
    set i1 $ix
    while {$j && [string compare {} \
    [set ix [$w search -back $c1 $ix $lim]]]} {
    if {[string match {\\} [$w get $ix-1c]]} continue
    incr j -1
    if {[string match {} $ix]} { set ix [$w index $lim] }
    } else { set ix [$w index $lim] }
    if {$::tk::console::blinkRange} {
    Blink $w $ix [$w index insert]
    } else {
    Blink $w $ix $ix+1c [$w index insert-1c] [$w index insert]
    # ::tk::console::MatchQuote --
    # Blinks between matching quotes.
    # Blinks just the quote if it's unmatched, otherwise blinks quoted string
    # The quote to match is assumed to be at the text index 'insert'.
    # Arguments:
    proc ::tk::console::MatchQuote {w {lim 1.0}} {
    set i insert-1c
    set j 0
    while {[string compare [set i [$w search -back \' $i $lim]] {}]} {
    if {[string match {\\} [$w get $i-1c]]} continue
    if {!$j} {set i0 $i}
    incr j
    if {$j&1} {
    Blink $w $i0 [$w index insert]
    } else {
    Blink $w $i0 $i0+1c [$w index insert-1c] [$w index insert]
    } else {
    Blink $w [$w index insert-1c] [$w index insert]
    # ::tk::console::Blink --
    # Blinks between n index pairs for a specified duration.
    # Arguments:
    # i1 - start index to blink region
    # i2 - end index of blink region
    # dur - duration in usecs to blink for
    # Outputs:
    # blinks selected characters in $w
    proc ::tk::console::Blink {w args} {
    eval [list $w tag add blink] $args
    after $::tk::console::blinkTime [list $w] tag remove blink $args
    # ::tk::console::ConstrainBuffer --
    # This limits the amount of data in the text widget
    # Called by Prompt and ConsoleOutput
    # Arguments:
    # size - # of lines to constrain to
    # Outputs:
    # may delete data in console widget
    proc ::tk::console::ConstrainBuffer {w size} {
    if {[$w index end] > $size} {
    $w delete 1.0 [expr {int([$w index end])-$size}].0
    # ::tk::console::Expand --
    # Arguments:
    # ARGS: w - text widget in which to expand str
    # type - type of expansion (path / proc / variable)
    # Calls: ::tk::console::Expand(Pathname|Procname|Variable)
    # Outputs: The string to match is expanded to the longest possible match.
    # If ::tk::console::showMatches is non-zero and the longest match
    # equaled the string to expand, then all possible matches are
    # output to stdout. Triggers bell if no matches are found.
    # Returns: number of matches found
    proc ::tk::console::Expand {w {type ''}} {
    set exp '\[^\\\\\]\[\[ \t\n\r\\\{\'\\\\\$\]'
    set tmp [$w search -backwards -regexp $exp insert-1c promptEnd-1c]
    if {$tmp == ''} {set tmp promptEnd} else {append tmp +2c}
    if {[$w compare $tmp >= insert]} { return }
    set str [$w get $tmp insert]
    switch -glob $type {
    path* { set res [ExpandPathname $str] }
    proc* { set res [ExpandProcname $str] }
    var* { set res [ExpandVariable $str] }
    default {
    set res {}
    foreach t {Pathname Procname Variable} {
    if {![catch {Expand$t $str} res] && ($res != '')} { break }
    set len [llength $res]
    if {$len} {
    set repl [lindex $res 0]
    $w delete $tmp insert
    $w insert $tmp $repl {input stdin}
    if {($len > 1) && $::tk::console::showMatches \
    && [string equal $repl $str]} {
    puts stdout [lsort [lreplace $res 0 0]]
    } else { bell }
    return [incr len -1]
    # ::tk::console::ExpandPathname --
    # Expand a file pathname based on $str
    # This is based on UNIX file name conventions
    # Arguments:
    # str - partial file pathname to expand
    # Calls: ::tk::console::ExpandBestMatch
    # Returns: list containing longest unique match followed by all the
    # possible further matche
