🎉Community Raffle - Win $25
Join and Win
Co-ordinates arrangements
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I have exported my model to .dat format for nastran solver.
While reviewing the .dat file, I found that, the co-ordinate points for nodes are not in same order (in terms of precision).
Is there any settings to keep the precision of the node co-ordinates same in all directions.
Sample is shown in image..
Thanks,
Prabhu P
1 - 6 of 61
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    There is a template command to set precision is *realprecision
    But I don't think that is a good idea, setting a low precision is similar to changing your node coordinates
    Altair Employee
    OP
    Hi Tinh,
    I am unable use the command.
    can you please give me an example on using this command.
    User: "tinh"
    Updated by tinh
    Could you explain reasons you have to set a low precision?
    Altair Employee
    OP
    Tinh,
    I am using my .dat file into excel to make some Quality Checks.
    In one process, we have to filter the co-ordinates of particular elements.
    We felt difficult in segregating the x,y and z co-ordinates, because they did not follow the uniform precision.
    For example, my X will be 1080.0125, Y will be 1524.012 and X will be 1526.12.
    In this, I cannot make automated segregation since there will be absence of space/tab in the dat file.
    In this case, we are expecting for uniform precision, at the level of 2 decimal places or 3 decimal places.
    User: "tinh"
    Updated by tinh
    Can't you import .dat file into excel with fixed width ?
    User: "tinh"
    Updated by tinh
    Hi Prabhu,
    using 'fixed width' option when import *.dat file to excel, you can easily separate x, y, z of nodes:
    don't need 'space' among them
