I am a new HyperMesh user and am learning it in context for LS-Dyna.
When creating a bolt though the connectors browser for LS-Dyna the only type available is a spider type (I assume this just creates a Constrained Nodal Rigid Body between the two parts).
When under the Radioss user profile making the same selection brings up many other bolt types, one of which is GENERAL which creates a spider at each end with a beam in the middle, exaclty what I want.
Is the fact that Hypermesh does not create this same bolt type for LS-Dyna a limitation of Hypermesh or of LS-Dyna?
I can go and create the bolt manually for dyna in a caouple of steps so I'm not sure why it would not be possible in Hypermesh for the Dyna profile?
Is this functionality going to be added for Dyna or am I missing something completely?
Thanks.
