🎉Community Raffle - Win $25
Join and Win
how to calculate cogging torque in permanent magnet AC generator using Flux 3D? kindly guide and suggest if any guiding document avaialble.
User: "Dattu B. Pawar"
Altair Community Member
Updated by Dattu B. Pawar
how to calculate cogging torque in permanent magnet  AC generator using Flux 3D? kindly guide and suggest if any guiding document available.
1 - 3 of 31
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    In the case of the cogging torque computation particularly in 3D, you need to refine the mesh in the air gap (it is better to create tow layer, one for the rotor air and the second for stator air). When you go fare form the air gap you can make relaxation on your mesh (goal: you don’t need to refine the mesh in all the parts of the motor).
    In Flux supervisor example, there is an example of cogging torque computation in the case of IPM motor.
    I attached a PDF file about the mesh in Flux.
    Thanks.
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    Thanks.
    Attached the file about the mesh.
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    There is alos another example in FLux supervisor.
    Flux 3D example >> application note >> axial flux motor
